codes. where to start.
Old Apr 5, 2007 | 02:57 PM
CamoA6's Avatar
Default codes. where to start.
My check engine light is on again for misfire codes and fuel trim running lean. I thought I should look for a vacuum leak. anyone else have any ideas?
Old Apr 5, 2007 | 04:04 PM
2k S4's Avatar
Default RE: codes. where to start.
What cylinder? I would check the plugs first, & swap the misfiring one. If it stays on that cylinder, swap the coil pack. If it moves to that cylinder, you need a new coil pack.
The LTFT, can be a faulty, O2, or EGT sensor that isn't bad enough yet to throw a code. Yes, you can check for boost leaks, but what bank were these on? The same?
Old Apr 5, 2007 | 11:40 PM
CamoA6's Avatar
I will check tomorrow. I have Vag-Com I will just copy them all down and post here. thanks for the help
Old Apr 6, 2007 | 02:43 AM
Vaudi's Avatar
Check for a leak..
Old Apr 6, 2007 | 02:51 PM
CamoA6's Avatar
The misfires have left and have not returned
Here is a small list of current faults I just cleared :
17538 - Fuel trim : Bank 1 (mult): system too lean
P1130 - 35 - 00 --
17536 - Fuel trim : Bank 2 (mult): System too lean
P1128 - 35 - 10 --- Intermintent
These are the things I am going to check:
- MAF sensor
- Fuel pressure
- Intake system for leaks
- O2 sensors before and behind cats
- Fuel injectors
Old Apr 6, 2007 | 04:48 PM
2k S4's Avatar
Do you have a Vag-com you can log block 115 & see if the actual & request is the same.? I would also check the EGT sensors, as per the Bentely manual. You can just unhook the MAF & drive it around, after you clear the codes, if they don't come back, try cleaning the MAF, if that doesn't work you will need a new MAF.
Old Apr 6, 2007 | 05:00 PM
techbod's Avatar
[IMG]local://upfiles/12092/6EB6237B56E847B7AC51479F3503D967.jpg[/IMG]
matt.mahoney
Dec 6, 2012 07:55 AM
R. Johnson
Feb 10, 2012 05:37 PM
oscar7120
Oct 6, 2011 06:30 PM
LRpgulf77
Feb 6, 2010 08:45 PM
quattrolove
Dec 19, 2007 10:59 AM
