coil pack replacement
2003 a6 3.0 quattro70k milesi need to replace 3 of my coil packs but im gonna just do them all at 1 time since ive been told the others can go at any time.... is this a DIY fix or should it be takin do a the dealer or could an indy shop do it? what plugs do u guys recommend? Are any coilpacks better then other thanks im a newbie
The ignition harness is the connectors on the ignition coils, the red connectors.
You will see two small little torx screws holding them to the valve cover.
Go ahead and replace the plugs, audi recommends replacing them every 35-40k on the 3.0L engine.
Papa_Dios
Sep 6, 2011 01:38 AM
