coil pack replacement
Old Nov 23, 2007 | 08:57 PM
paaudia6's Avatar
Member
Default coil pack replacement
2003 a6 3.0 quattro70k milesi need to replace 3 of my coil packs but im gonna just do them all at 1 time since ive been told the others can go at any time.... is this a DIY fix or should it be takin do a the dealer or could an indy shop do it? what plugs do u guys recommend? Are any coilpacks better then other thanks im a newbie
Old Nov 23, 2007 | 10:11 PM
auditech79's Avatar
Default RE: coil pack replacement
They are easy to do on a 3.0L, they are just a pop in kind. You have to remove the two T15 torx screws holding in the ignition harness then pull them straight up.
Old Nov 23, 2007 | 10:19 PM
paaudia6's Avatar
Member
ok where is the ignition harness im new to audi dont lill me lol.... should i do the plugs at the same time or just wait until the 80k service? gapping of the plugs hard to do?
Old Nov 23, 2007 | 11:57 PM
auditech79's Avatar
The ignition harness is the connectors on the ignition coils, the red connectors.
You will see two small little torx screws holding them to the valve cover.
Go ahead and replace the plugs, audi recommends replacing them every 35-40k on the 3.0L engine.
Old Nov 24, 2007 | 06:30 PM
paaudia6's Avatar
Member
auditech do i just simply put the plugs in? do i have 2 worry about the gaping stuff?
elis
Dec 7, 2011 10:37 AM
Papa_Dios
Sep 6, 2011 01:38 AM
The one who saw the way
May 21, 2011 10:19 PM
rocktbone
Sep 9, 2010 08:55 AM
p1zl3
Jul 12, 2007 09:42 PM
