Coolant Temp sensor
Old Oct 24, 2006 | 12:12 AM
rramsa01's Avatar
Default Coolant Temp sensor
Hi All
I am trying to replace the Coolant temp sensor (2002 A6. 3.0 eng). I spent 2 + hours trying to install the retaining clip, I even tried using a smaller 0-ring no good any ideas and/or suggestions,
Thanks in advance.
Old Oct 24, 2006 | 12:34 AM
mpw2.7T's Avatar
Default I suspect you checked, but are you sure the old o-ring isn't stuck in there?
isn't stuck in there??
Old Oct 25, 2006 | 03:43 AM
rramsa01's Avatar
Default RE: I suspect you checked, but are you sure the old o-ring isn't stuck in there?
Thanks. when I removed the defective part I was sure the old o-ring came with it and fell onto the lower eng cowling, I guess that was not the case as there was an old o-ring still in the housing.
Thanks Again.
burak
Oct 23, 2009 07:21 PM
dhenson2342
Mar 14, 2009 08:04 PM
JL AUDI
Mar 9, 2006 01:38 PM
