coolant warning is on! what now??
GUYS I NEED HELP
MY A6 4.2 OVERHEATING
WATER TEMP IS ON "H" AND COMPUTER ASKING ME TO CHECK COOLANT LEVEL
WITCH IS FINE
OIL TEMP. IS FINE <250
i NOTICED THAT 2 SMALLER FUNS ON THE RADIATOR DOE'SN'T WORK!!!!!!!!!!
when are they supouse to kick in??
some kind of thermo switch???
( sorry I'm guessing)
coolant reservoir and radiator are hot so I think thermostat and wather pump are fine too!!!
what do U think
is ther any fuse controling this 2 fans on the radiator?
THX!!!!!!!!!!1
WITCH IS FINE
what do U think
THX!!!!!!!!!!1
There is a TSB at audi for the fan control module having wiring problems, the fix is installing an overlay harness. Take it to the dealer and tell them both of your fans aren't working. Im not sure if it applies to the 4.2L engine but thats what it sounds like.
How did you make out? My temp guage was at 4/5ths today, constant on highway and local stop and go, and no change when i turned on AC (which should activate aux fan, I assume). So I'm thinking sending unit, but...
Your thermostat is like stuck closed. It blocks the coolant flow and the fans don't come on because the heated coolant dosn't reach the fan switch. The over heat light looks very similar to the low coolant light.
does anybody knows what the problem is when overheating temp guage all the way up, coolant full ,big fan (radiator fan )dont come on but the two smaller fans do come on even when i turn off the car.the a/c blows cold with nomal temp thenblows hot when the guage goes up ,the car dont pull as it used to. it is losing power.
