Crankshaft sensor!
Hi, my car was shutting off at random, at the most uncomfortable times ofcourse... No hesitation, nothing just shuts off while driving or standing at a stop light, and would not start after that.
Got engine faults, is says P0332 - engine speed sensor - no signal.
checked the manual, engine speed sensor aka frankshaft position sensor with grey plug and 3 contacts under the coolant expantion tank. Got it tested with multimeter, contacts 1 and 2 have 900ohms (if I'm reading myltimeter the proper way
) everything esle is no contact.
Ordered new sensor, got it today, it shows exactly the same 900ohms, what;s wrong? The test does not mean anything and old sensor might be still bad, or something else going on>?
Can I have a broken wire from sensor to ECU? Does anyone know to what pins in the ecu the sensor is connected so I can check the line?
car is 2.8 aha, automatic transmission.
Thank you.
) everything esle is no contact.Ordered new sensor, got it today, it shows exactly the same 900ohms, what;s wrong? The test does not mean anything and old sensor might be still bad, or something else going on>?
Thank you.
Sorry, my bet, it's P0322 =)
The scaner called it to be Engine speed sensor. I checked my dumb audi manual and the thing I bought is called the 'engine speed sensor' in there.
Can you please check your manual for the correct code?
Thanks.
Thanks.
For P0322, the Bentley says:
[align=center]P0321[/align]
[align=center]16705[/align]
Ign./Distributor Eng. Speed Inp. Circ.
Range/Performance
[align=center]2 Dcy[/align]
- Check engine speed (RPM) sensor -G28-
Page 24-86
[align=center]P0322[/align]
[align=center]16706[/align]
No Signal
[align=center]Immed.[/align][align=center][/align][align=center][/align][align=left]Here's the process for checking the wiring between the ecm and the sensor:[/align][align=left][/align][align=left]
Check wiring for open circuit between ECM/test box and 3-pin harness connector.
Connector terminal 1 to ECM/test box socket 67
Connector terminal 2 to ECM/test box socket 63
Connector terminal 3 to ECM/test box socket 56
Specified value: max. 1.5
Check wiring for short circuit between ECM/test box and 3-pin harness connector, according to wiring diagram.
Connector terminal 2 to ECM/test box socket 67
Connector terminal 1 to ECM/test box socket 63
Connector terminal 1 to ECM/test box socket 56
Specified value:
If wiring is OK:
Replace engine speed (RPM) sensor -G28-.
Check readiness code
Page 01-80 . If Diagnostic Trouble Code (DTC) memory has been erased, or ECM was disconnected, generate new readiness code
Page 01-83 . [/align]
Range/Performance
No Signal
Specified value:
If wiring is OK:
Hopefully I understood the test completely:
term 1 to socket 67:
term 2 to socket 63:
term 3 to socket 56:
100% connection, 0 resistance.
term 2 to socket 67:
term 1 to socket 63:
term 1 to socket 56:
No connection
Is that what it suposed to be? Then I have bad sensor right?
I guess sensors own resistance does not really mean anything in this case.
No connection
hey, so did you have any avail with the crankshaft position sensor? i have the EXACT same problem and have been trying to fix it for weeks but can't seem to get it. hopefully there will be some response as i am STUMPED! I had the local indi shop replace the crankshaft sensor and it didnt do anything....
