Credit Card / Coins TRAY
Hello,
for some reason the credit card / coins tray does not go all the way in so I can not have it fully closed.
Any solution to this pls...
Its an Audi A6 2000 2.8 Quattro
If there is a step by step procedure how to remove it and see what is stuck in there would be greatly appreciated.
Thank you in advance,
Mario.
Mario.
same thing happened to mine...coins were stuck back there. i just pulled it out and reassembled. it's nothing special, you gotta pry into the plastic to push back some tabs back and the thing slides out. search around first to get the location because it is pretty fragile. i can't seem to find it right now
Its a definite PITA. The "clips" that hold it in are on the top corners. You have to push them down from the top and the one on the left side is darn near inaccessible. Don't pull too hard on the tray or it will "explode" (cut my chin, don't ask). When you pull the trim piece you are most definitely going to break a few of the clips. Mine is holding fine with three, one on each side and one in the middle.
I saw a write up somewhere. Check audidiy.com
The coin/card tray is held in by the same mechanism that holds the radio in. To remove it properly you need i think two of the audi/vw radio removal tools (like this) to insert into the slots above the tray. Then it just pops right out easy peasy. I've done this personally so i know it works *shrug*
I googled the Radio Tool Removal Audi and found some on ebay for $5 shipped! :-)
Let ya know in a few days if they
Hi gordog1962,
You are the winning buyer for the item below. Thank you for your business!
Item title: 4 VOLKSWAGEN MERCEDES AUDI VW RADIO REMOVAL TOOL RRK132
Web address: http://cgi.ebay.com/ws/eBayISAPI.dll...m=360259571563
Item number: 360259571563
Buyer User ID: gordog1962
Seller User ID: uneeksupply
Your total is:
$5.35 per item
insurance
$0.00 Sales discounts (-) or charges (+)
$0.00 shipping/handling
$5.35 = Total
Hi gordog1962,
Your total is:
$5.35 per item
insurance
$5.35 = Total
orconquest
May 27, 2009 09:37 AM
