Electronic Cam Adjuster on 04 A6 2.7T
Old Feb 27, 2006 | 11:12 AM
gdebruin's Avatar
Default Electronic Cam Adjuster on 04 A6 2.7T
My Check Engine light goes on and off intermittently and sometimes my car makes a noise like it's out of oil. The dealer tells me the code reads a problem with the "electronic camshaft location adjuster". It will cost US $1600 to fix. Has anybody ever heard of this? Am I being taken for a ride? My car is a little more than 2 years old with 58,000 highway miles on it (just off warranty).
Old Feb 27, 2006 | 11:41 AM
techbod's Avatar
Default RE: Electronic Cam Adjuster on 04 A6 2.7T
its called a camshaft position sensor costs approx $90 it cant be repaired a new one is required $1600 hell is it 24ct gold and approx 10 minutes to change
[IMG]local://upfiles/12092/5B8D5C0844EB46D2B9D4255478FA4624.jpg[/IMG]
Old Feb 27, 2006 | 01:29 PM
gdebruin's Avatar
Thanks for the quick answer. You just saved me a bundle!
Old Feb 27, 2006 | 01:39 PM
techbod's Avatar
that's what we are here for ( dealer stuffers )
Old Feb 28, 2006 | 01:45 AM
dankhound's Avatar
With a price tag that high im guessing you were quoted for replacing the camshaft adjuster. Totally different than a camshaft position sensor. If your car makes a noise like its out of oil you may not have an electrical problem at all. The camshaft adjuster is the last item to recieve oil and it uses oil to adjust the cam timing. No oil equals no adjustment and a code for a faulty adjuster.
Old Feb 28, 2006 | 08:14 PM
AudiTech04's Avatar
ORIGINAL: dankhound
That is the correct answer
Doing this basicly includes doing a T-Belt service (well kinda) you have to remove the cams, so you also have to remove the timing belt too that why labor is so much
kcarlson30
Oct 8, 2014 05:22 PM
steviep6
May 30, 2013 10:52 AM
vtraudt
May 26, 2011 09:22 AM
02A418T
Oct 26, 2007 06:26 PM
equipe9
Aug 5, 2005 07:54 PM
