Electronically Adjusted Steering Wheel
Old Aug 28, 2007 | 10:56 AM
Blade69's Avatar
Default Electronically Adjusted Steering Wheel
Mine is manual tilt and telescoping steering wheel. Can I put the electronic one in with no issues? Since I'll be taking out the stock stereo, there is no need for the steering wheel controls. Plus I would prefer the shift buttons on the steering wheel anyway if they are available on the electronically adjusting steering wheel.
Thanks.
Old Aug 28, 2007 | 02:03 PM
Blade69's Avatar
Default RE: Electronically Adjusted Steering Wheel
Seems that the steering wheel and the electronic adjusting may be separate items. I found a steering wheel that actually had the radio functions, and the shifting buttons. So what I'm looking for is the electronically adjustable steering column I think. Does anyone know for sure if they are separate?
Old Aug 30, 2007 | 01:18 PM
Blade69's Avatar
I cannot be the only one that has thought about this.......[]
Old Aug 30, 2007 | 02:28 PM
auditech79's Avatar
You would need a completely new steering column, the wiring harness going to the steering column would have to be altered, and you would have to change the central convience module to give control over the system. All in all its basically not affordable, thousands of dollars.
JustWondering
B7 Models
Sep 11, 2011 11:17 AM
Audi S4 Turbo
Apr 22, 2010 10:42 PM
Colex
Audi Q7
Feb 16, 2008 10:19 PM
Blade69
Aug 28, 2007 12:33 PM
