Engin running when bleeding brakes?
Old Aug 22, 2009 | 12:21 PM
james0013's Avatar
Default Engin running when bleeding brakes?
This sounds like a really elementary question but when you bleed the brakes should you have the engine running?
The reason I ask that I replaced the brake fluid in my car and now when I brake and the ABS cuts in hear a noise that sounds like a vacuum pump from behind the drivers dash.
Old Aug 22, 2009 | 12:25 PM
Jackmup's Avatar
No you don't run the engine. However use a little tube or hose and protect your tires from the fluid. You may want to pull them off. The fluid will eat the rubber.
Old Aug 22, 2009 | 12:28 PM
james0013's Avatar
OK thanks, I actually did the fluid swop about 600 miles ago and I did use a tube to move the fluid away from the car so as not to get it on the paint or anything else. I had the car on 4 jack stands when i did it.
james0013's Avatar
I guess I will have to do more investigation for the source of my noise, but I am sure its a vacuum pump sound
1275 sprint
May 26, 2015 02:20 PM
steve53mg
B7 Models
Oct 15, 2013 01:11 PM
oldmots
Jul 22, 2010 04:09 PM
kevace1
Dec 28, 2009 01:09 AM
GT5 S
Nov 27, 2006 04:56 PM
