Engine Fault Codes Please Help
Old Jul 29, 2008 | 02:07 PM
michaelh305's Avatar
Default Engine Fault Codes Please Help
I pulled the following fault codes And suggestions? P1423, P1411, P1476, PP1138, P1136, P1129, P1127. What does it mean?
Old Jul 29, 2008 | 02:24 PM
Jeffla's Avatar
Old Jul 29, 2008 | 02:41 PM
Default RE: Engine Fault Codes Please Help
it is a leak detection pump failure or a blocked line any suggestions?
Old Jul 29, 2008 | 05:27 PM
kimi's Avatar
how does the car behave? and what pump are we refering to? i will be glad to make any suggestion and recomendation if i can
Old Jul 29, 2008 | 05:34 PM
for the P1476 It's a leak detection Pump Failure located in the Drivers side rear wheel well. P1127 and P1129 are bank 1and2 too rich.
Then P1136 and P1138 are bank 1and 2 are too lean any help?
Old Jul 29, 2008 | 06:10 PM
hxgaser's Avatar
Vacuum leak somewhere?
Old Jul 29, 2008 | 06:17 PM
I checked underneath the hood and took off nearly everything on the pass. side and the wheel skirt I did not notice a vaccum leak
Old Jul 29, 2008 | 06:20 PM
I check for a vaccum leak under the hood and the pass side wheel well didnt see or hear any. Where do i start
vassar007
May 26, 2010 05:25 PM
chapdiggy
Sep 18, 2008 08:01 PM
chapdiggy
B7 Models
Sep 7, 2008 07:52 PM
marko_tomas13
Aug 9, 2008 01:49 PM
BaconBait
Jun 30, 2006 01:54 PM
