Engine and Tip Fault Codes
Old Aug 9, 2008 | 12:40 AM
marko_tomas13's Avatar
Default Engine and Tip Fault Codes
Hey everybody, I just scanned the car today ('99 A6 2.8) to see the fault codes that came up due to a CEL and I got the following:
1 Fault Found:
17800 - Camshaft Position Sensor Bank 2 (G163): Open Short to Plus
P1392 - 35-10 - - - Intermittent
I was betting on this being a faulty sensor that I could replace but now i'm not so sure. Anyone have any suggestions or a general area of where I could locate the sensor?
Also, I was a little surprised to find a Trans fault code:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Implausible signal also seems like a faulty switch...best bet just to replace it? Funny thing is all brake lights work fine and i've noticed no problems.
Thanks for any help.
Old Aug 9, 2008 | 01:49 PM
kimi's Avatar
cam position sensor bank 2 is found: drivers side upper posterior of the engine. to gain access you may have to carefully move the water resavoire tank in the best way you can.
vassar007
May 26, 2010 05:25 PM
chapdiggy
Sep 18, 2008 08:01 PM
chapdiggy
B7 Models
Sep 7, 2008 07:52 PM
michaelh305
Jul 29, 2008 06:20 PM
BaconBait
Jun 30, 2006 01:54 PM
