Fault transmission range switch
I told you it comes down to what your symptoms are. If you are having trouble engaging the reverse gear (like its slipping) then its the MECHANICAL neutral safety swtich like in the write up. Which is holding the gear out of place/sending incorrect signals.
Or, if you can't engage reverse or any other gear at times when the lights are flashing, this would be an electrical problem from the TR switch.
Based upon that information you have to decide which one to replace.
you have been most helpfull i have decided and i am now looking to source the part here in the UK, as its mechanical, again many thanks
gone postal
Sep 16, 2009 11:57 PM
17090, audi, circuit, forum, p0706, range, rangeperformance, replacement, replacing, reset, selector, sensor, switch, tr, transmission
