Faulty Brake Switch Symptoms
Old Jun 19, 2008 | 01:03 AM
fidelite's Avatar
Default Faulty Brake Switch Symptoms
In the winter my ABS light would randomly turn on (Disabling ECS as well), then off, reading the forums, it seemed to be a faulty ABS module. In the summer the ABS light became more steady and of course when I took it to Audi it would turn off for that day... Soon after I found I couldn't use cruise control, and after that all the brake lights in the back went out, if it got worse, it would basically not be able to come out of park. The part is $5.00 and the instructions kinda sucked, but once I replaced it, all the above started to work.
Hopefully this helps someone diagnose theirs
Old Jun 19, 2008 | 07:50 AM
massboykie's Avatar
Member
Default RE: Faulty Brake Switch Symptoms
ORIGINAL: fidelite In the winter my ABS light would randomly turn on ...
I had exactly the same issues with the ABS light randomly turning on. The first tiem it happened it freeked me out, I reset it and could notsee anything else wrong with VAG-COM.Eventually took it in to let the warrantee take careof it...
Cheers
Massboykie
Old Mar 16, 2009 | 12:07 PM
NH_USA's Avatar
where are you finding a brake light switch for $5?
jaredlipsitz
Oct 6, 2014 03:29 PM
BigBadDave
B7 Models
23
Sep 17, 2014 08:11 PM
98quattro
Mar 30, 2007 05:58 PM
leelewis
Jul 11, 2006 05:06 PM
AUDI A6 2.5 TDI
Apr 6, 2006 08:21 PM
