Front end squeak - strut bearing?
Old May 26, 2009 | 04:43 PM
68jcode's Avatar
Originally Posted by kevin1533
Does it happen after driving for while? I had this horrible squeeking sound that occured about 20 minutes into my drive. Sound can be produced when I turned my wheel.
Nope, happens right away.
Old May 26, 2009 | 04:46 PM
68jcode's Avatar
Originally Posted by auditech79
Am i the only one that doesn't know what a strut bearing is??.......
Do you mean the strut mount bushing? That could cause what you're talking about, the other likely cause would be the upper control arm bushings, that squeak you can replicate by pushing down on the fenders, if you hear the squeak then its the upper control arm bushings.
If the noise only happens when turning, then its likely the tie rod ends.
There is also a bearing located within the bushing, but is a seperate piece. Not sure if the bushing could also make this noise. The difference with this squeak from others I have read is it can only be reproduced by turning the wheel and NOT by pushing down on the suspension, which is why I didn't think it would be the control arm bushings. With almost 100k on the car, I might just replace all the wear items in the front suspension and be done with it.
Old May 26, 2009 | 06:38 PM
Midniteoyl's Avatar
Would be the best bet... it really improves the ride.. more than you'd think.
Mossyoakglock
May 5, 2014 02:03 PM
Smecker
Aug 16, 2008 08:10 PM
mmwjade07
Aug 4, 2008 05:50 PM
zelpdsm
Jun 6, 2008 07:55 PM
600konmy90
Oct 24, 2007 03:08 AM
