Gas leak...
Old Aug 29, 2007 | 09:24 PM
TopGUn86's Avatar
Default Gas leak...
I have a small gas leak. It only leaks for a few minutes after the car has been running. Not a large abount of gas.. but an annoying leak. and ideas?
Old Aug 29, 2007 | 11:15 PM
marko_tomas13's Avatar
Default RE: Gas leak...
ORIGINAL: TopGUn86
Leaks from what spot?
Old Aug 31, 2007 | 05:17 PM
TopGUn86's Avatar
the leak is near the gas filler tube. right behind the rear passanger tire
Old Aug 31, 2007 | 07:46 PM
auditech79's Avatar
Its probably the filler neck assembly, its seperate from the tank on an A6 and has tons of lines going to it.
Take off the right rear wheel, then remove the fender liner then you will be able to see where the leak is coming from.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
