Grease on 4 wheels
Old Nov 2, 2008 | 02:17 PM
kbunting's Avatar
Default Grease on 4 wheels
A-6 2.7 Turbuo Quatro Sedan
Today while doing the weekly wheel washing to keep brake dust off the alloys, all 4 wheels had traces of grease that was extremely difficult to remove.
Usually this would mean whell bearing failure to me but 4 wheels simultaneously is a bit confusing.
There are no noises and the car was not just in for a grease job so I don't know what could cause this .
Any ideas ?
Thank you in advance
Kurt
Old Nov 2, 2008 | 02:19 PM
Retard Riot 686's Avatar
Cv boots/joints might be bad/cracked
Old Nov 2, 2008 | 04:47 PM
Stampy's Avatar
CV boots......or maybe you drove is some freshly paved streets???
Old Nov 2, 2008 | 05:54 PM
Coors's Avatar
C/V boots are probably torn. Tires may have been rotated post-c/v tear. Hence the grease on rear wheels???
Old Nov 2, 2008 | 10:53 PM
audi_sf's Avatar
Here is what you need to do.
1) Turn on your car and turn the wheels ALL the way to the right.
2) Get under the car BEHIND the wheel by the dirvers side with a flash light. Shine it into the wheel well and see if your CV boots look like THIS: https://www.audiforums.com/forum/sho...=109929&page=2 If they do, then you need new cv boots. Cost at a shop of $200-300 per including labor
3) Turn the wheels all the way to the other side and repeat for the passengers side.
Old Nov 3, 2008 | 07:49 AM
bob martin's Avatar
I don't know, all four CV boots at the same time? Not unless someone was f***in with you! Same for wheel bearings. One at a time, yes. All four at once? No way! I support the "you drove through something" argument. But, check your CV joints to make sure one of them wasn't the culprit (althoug, when cleaning the wheels, you can tell if one went bad!).
Bob
Old Nov 3, 2008 | 09:32 AM
hxgaser's Avatar
Wheel bearings on our cars are closed sealed I think. You shouldn't have an oil leak like that. I would just clean it and see if it comes back. It could just be some residue from the shop.
bobl2
Apr 5, 2015 01:30 PM
Buttery Cracker
May 9, 2007 07:28 PM
Altt180
Nov 17, 2006 07:31 AM
dasipher
Jul 23, 2006 05:06 PM
tmack
Aug 31, 2005 07:14 PM
