Had EGR CEL and pulled valve covers...
Old Oct 23, 2009 | 06:45 PM
  #21
chefro's Avatar
ohhh that would be great!
Are you serious about it?
Old Oct 23, 2009 | 09:54 PM
  #22
a6hcw's Avatar
You don't need to remove the intake manifold. Just remove the throttle body to get the EGR sensor out. You only need to modify a 14mm deepwell socket with a slit like an oxygen sensor socket has for the wire. There are a bunch of wire ties that have to be removed. The sensor may be tested with an ohm meter and boiling hot water, per Bentley. Be sure to put antiseize compound on the sensor before reinstalling it.
Old Oct 24, 2009 | 01:29 AM
  #23
Midniteoyl's Avatar
Mmm... Not quite that way on the 12v...
Old Oct 24, 2009 | 11:39 AM
  #24
a6hcw's Avatar
I have done this with the 2.8L 12 valve AFC engine on my 1996 A6 Quattro sedan. There is just enough room for a small 1/4" socket wrench and a 14mm deepwell socket slit for the wire. If the EGR sensor is very tight, just put a hose clamp around the tip of the socket to keep it from spreading wider and use a small pipe on the wrench handle.
The EGR sensor is as shown in Cefro's pictures at the bottom of the intake manifold near the throttle body opposite the EGR valve.
Old Oct 24, 2009 | 01:48 PM
  #25
Midniteoyl's Avatar
DOH!! You said sensor... Sorry I kept thinking about the EGR valve itself...
rmr1499
Mar 16, 2014 10:41 AM
drvirago777
Jul 3, 2013 10:31 PM
pbbg
Nov 29, 2010 09:32 AM
fullercustoms
Jun 30, 2010 03:27 AM
audilover04
Aug 31, 2005 08:33 PM
