Headlight adjuster not working. Is there a quick fix?
Old Jun 9, 2011 | 10:05 AM
Bklynrx7's Avatar
Arrow Headlight adjuster not working. Is there a quick fix?
I realized recently that both of my headlights were basically aimed at the ground. I had very limited sight distance on a recently drive through some poorly lit roads and Im trying to resolve the problem before I leave tonight for 7 hour drive through the night.
The DS headlight adjusts fine on both axes, but the PS light will not adust up or down, the white gears on the back appear intact but there is no resistance compared to the DS. Is there another way to adjust them? Can these gears be worked on by removing the back cover of the light or would I have to remove the whole assembly?
Thanks in advance for your help.
Old Jun 10, 2011 | 08:32 PM
bob martin's Avatar
First, pull fuse 10. Second, try manually adjusting the lights. If the gears spin free, you need a new assembly.
Bob
azzy28
Jan 29, 2012 11:03 AM
y^0
Jun 14, 2010 01:47 AM
gwos25
Sep 5, 2009 11:41 AM
s4_hj
Aug 27, 2009 12:29 AM
NuYorka103185
Feb 12, 2008 12:17 PM
