help 3.0 engine no compression might need new engine
Old Nov 20, 2013 | 08:02 AM
mlake's Avatar
Got car for 200 I checked heads with a straight edge and a filler gauge at diffrent points . Impeller was fine not broken off .
Old Nov 20, 2013 | 09:02 AM
mlake's Avatar
Ok order head gaskets kit both sides, head bolts, valve covers both sides intake gaskets , water pump. Timing belt, all pullys crank bolt, cam tool .
Old Nov 20, 2013 | 10:21 PM
mlake's Avatar
Got head tore down removed bent valve only question I have is what do I use to seal cam carrier back to head ?? Will Indian head gasket shellac work ??
Attached Thumbnails help 3.0 engine no compression might need new engine-imag0275.jpg   help 3.0 engine no compression might need new engine-imag0274.jpg
Old Nov 20, 2013 | 10:42 PM
mlake's Avatar
New valve came in quick 1 day
Attached Thumbnails help 3.0 engine no compression might need new engine-1385005238964.jpg
Old Nov 21, 2013 | 10:51 AM
mlake's Avatar
New valve in had to make tool it was a 7/8 hole saw . Used spring compressor on top of that was able to get keepers back in .
Attached Thumbnails help 3.0 engine no compression might need new engine-1385048904280.jpg
audivw_recycling
Mar 12, 2013 02:05 PM
MPLSChase
Apr 14, 2009 06:56 PM
MPLSChase
Apr 9, 2009 05:14 PM
hiwords
Oct 5, 2007 12:17 AM
pyropenguin
Sep 27, 2006 02:20 AM
