Help with boost prob
When you drive the car normal its fine but on a hard accel. when you get to about 40 say on a on ramp acceleration I get the two lamps on for low boost. Seems to not take off like it used to.
codes although check engine light not on.
P1453 EGT sensor 1 circuit bank 1 open circuit / short circuit to B+
P1423 Bank 1 secondary air system flow to low
P1555 Value above max charge pressure
P0103 Mass or volume air flow circuit high input
P0130 O2 Sensor Circuit B1 S1
P1548 Wastegate bypass regulator valve open circuit.
With all the circuit codes Im leaning toward electrical any common known issues out there?
