Help A/C leak!
Old Aug 19, 2010 | 01:02 PM
2.7heaven's Avatar
Default Help A/C leak!
Ok, so all was well, on my 2000 A6 until one day I noticed a large amount of water in the rear passenger-side foot area of the car. I followed the water's trail, and determined it was coming from under the dash through this spongy thing. It only leaks when the A/c is on. Could anyone please help me out here? My A/C is useless since it will damage the interior, and I live in Texas these 100 degree days are killer.
Old Aug 19, 2010 | 05:26 PM
jc66's Avatar
I have a 2005 A6 Avant. Same problem, water in passenger f/r footwell. Told that drain pipe on underside of vehicle was blocked. You should find this once black material cover is removed by undoing two 10mm nuts. Pull back cover from bodywork and you should find a rubber bung. Take this out give it a clean and cut a small v shape on bottom side of flap. This I have been told will cure the problem. I have done this today and have my fingers crossed. PS also drying out carpets now. Best of look. JC 66
Old Aug 20, 2010 | 11:47 AM
2.7heaven's Avatar
Thanks for the reply. Let me know if this works out for you.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
