HELP!changed cont arm, now ESP+ABS lit up
Old Feb 4, 2009 | 05:29 PM
marcb0127t's Avatar
Exclamation HELP!changed cont arm, now ESP+ABS lit up
I just changed my tie rod ends and a lower control arm. Started driving, stepped on gas a little and ESP warning flashed, along with my antilock brakes engaging at the same time...Now both warning lights, ESP and ABS are lit up. They go off when I restart car, but when I start driving again, same thing happens...I wiggled both wires, abs and esp to make sure they didnt come loose, but no chsange...
Old Feb 4, 2009 | 06:56 PM
freakaftr8's Avatar
Member
Did you pull a wire or connector when you disassembled the front end? Did you use excessive force when you disconnected the harnesses? Or did you happen to pull the connectors apart by pulling on the wires instead of the plastic connectors? I had this happen in wiring before.. The best way is to ohm out the wires between connectors. Use an ohm meter and poke each wire before and after the connectors and see of one wire is open, then you will know if a wire connection is at fault. If so, you will need to repair it. Most likely a wire to pin connection broke in your abs sensor. If not a connection problem, disconnect your battery with your headlights on, leave it disconnected for an hour, and reconnect and test drive..
Good luck
BTW, you might have an adjustment issue on your ABS sensor. When you step on the gas, your hub has a tendency to shift a bit, and you might have something still loose too. When you apply power to the wheels, and your preload is not correct on the retaining nut, it might be shifting causing a misalignment of the ABS sensor to reader. The reason your ESP is acting up is because your car thinks that wheel locked up.. Your ABS is doing the same..
So it could be bad ABS wheel sensor, misalignment, bearing issue, broken wire, or ECM reset
Old Feb 6, 2009 | 12:20 AM
marcb0127t's Avatar
got a front end alignment after buying new tires, problem solved...It never amazes me anymore how sensitive these cars are..Thanks for the help though...
Old Feb 6, 2009 | 12:41 PM
freakaftr8's Avatar
Member
no prob. glad to hear it's fixed
style
Dec 13, 2009 01:47 AM
IdriveAsilverA3
Jul 20, 2008 12:50 AM
millenia
Feb 4, 2008 11:48 PM
xpuser8334
Oct 31, 2006 01:36 AM
prbayha
Oct 2, 2006 12:45 PM
