Help! Nav Question
The good news is you should be pre-wired for Nav unit in the trunk. The bad news is that you are not pre-wired for the satelite attena on the roof. You will either have to take the car apart to run a line to the satelite attena, or you will have to use one of those cheesy after market satelite attenas.
can anyone help me out? I have a 2008 A6 Wagon, full MMI, Sirius radio with the antenna on the roof. the car was ordered w/o GPS. what do I need to do to install it...I'd really like to have it. any help and knowledge is greatly appreciated
You need to have the hardware unit installed in the trunk. There is a mini computer rack on the left hand side. You then need to purchase the software from Navtech. Because the car was not ordered with the Nav unit the Satelite antena on the roof is not wired for the Nav unit. Therefore you will either have to run a wire to the antena or get an aftermarket cheesy satelite antena. The total price to have the dealer install it will run you about $2500. If you do it yourself, the parts will run you about $2,000.
Kevin, mine is a wagon...so where is the 'hardware rack'? also is there any chance the wire is already in the antenna? and if not where does it run to (front or back of car) and do you have any audi part numbers?
thanks so much
thanks so much
Audi did not wire the antenas unless the car came with the NAV unit. I don't know where the rack is in the Avant. Take a look on the left handside of the rear of the car and see if it has some time of door or hatch.
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
