Help with these codes!
Old Oct 18, 2007 | 07:54 AM
adrenalic's Avatar
Default Help with these codes!
99 A6 Quattro.
CEL comes on for few days then goes away and back again.
I got the following codes:
01- Engine:
1. 16716- Knock Sensor 2 (G66) signal too low...
P0332 - 35-00
2. 16825 - EVAP Emission control system :incorrect purge flow
P0441 - 35-10
3. 16500 - Engine coolant Temp: circ range/performance
P0116 - 35-10
02- Auto Trans:
1. 00526 - Brake light switch -F: Implausible signal
27-00
My questions are:
1. do I replace the sensor or something else. what does it exactly means.
2. would replacing the purge valve correct this code or do I need to check for something else.
3. engine coolant temp sensor needs to be replaced?
4. I believe my brake lights are working fine. what does that code mean then?.
any help would be very much appreciated.
please be very generous with your explanations. I'm no car technician. but I replaced few things in my car. thanx.
Old Oct 19, 2007 | 11:38 AM
adrenalic's Avatar
Default RE: Help with these codes!
did I post this in the wrong forum?!. hmmm.[X(]
Old Oct 19, 2007 | 11:43 AM
techbod's Avatar
P0441 - 35-10
an air leak check all the pipes for leaks yo the EVAP purge valve
edit: speller checking[:@]to the not yo the
Old Oct 19, 2007 | 11:50 AM
techbod's Avatar
all the codes make it one thing and that's the EVAP system and all the codes coincide to one item, codes are only a guide it takes expertise to determine the fault and im not the best
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
