Sponsored by:
Sponsored by:
HELP - Transmission Oil - 2.7T Tiptronic
Old 06-11-2007, 04:37 PM
jonno77's Avatar
Default HELP - Transmission Oil - 2.7T Tiptronic
Just wondering what I should be using to refill my transmission. I have read plenty on the factory ESSO EGL71141. I read a little about the VW auto tranny fluid. What should I be looking for if I go to the VW dealer? Is there NOT a good store bought brand I can use instead of factory fluid? I just need to refill the pan. Yes I made the transmission instead of engine oil mystake. How much oil did I drain out??
Any help please!
Old 06-11-2007, 04:40 PM
Jeffla's Avatar
Default RE: HELP - Transmission Oil - 2.7T Tiptronic
You emptied around 4 quarts. Just go to the dealer and buy it. I would buy 5.
Jeff
Old 06-11-2007, 05:12 PM
2k S4's Avatar
You might as well flush it, & put in a new trans filter.
Do a search, we have talked about the proper way to flush & fill the trans. You will need a pump for the fluid.
I put Redline D4 ATF in mine, so it seams to like it.
rmr1499
07-16-2013 01:11 PM
the Anno
09-18-2011 08:05 PM
vanbragt
04-18-2010 10:45 AM
h8state
03-31-2008 10:15 AM
matoida6twin
03-01-2007 07:49 PM
Quick Reply: HELP - Transmission Oil - 2.7T Tiptronic
