transmission 2.7t tiptronic
Old Feb 28, 2007 | 10:40 PM
matoida6twin's Avatar
Default transmission 2.7t tiptronic
ok, this doesn't happen often but sometimes when coasting at low speeds the tranny seems to be unsure of what gear to shift to. sometimes it just hangs in neutral for a second and then kicks hard into a gear. i was wondering if anyone has encountered this problem and would a fluid change help anything. ever since the first time it happened i have been scared of doing damage to what i understand to be an expensive component. any suggestions?
Old Mar 1, 2007 | 02:07 AM
Vaudi's Avatar
Default RE: transmission 2.7t tiptronic
It is possible there is something wrong with the TCM, OR thier could be an update for the TCM. If you know someone with a VAGcom they could scan the TCM. What year, engine?
Old Mar 1, 2007 | 03:00 AM
thanks, i need to ask my indy guy, he's probably got one. hopefully it's something easy. i just spent a lot on it having seals replaced and timing belt and water pump. it is a 2000 a6 2.7t tipronic. thanks again.
Old Mar 1, 2007 | 03:31 PM
2k S4's Avatar
Changing the fluid would not hurt. Mine shifts much smother & faster after flushing out the old nasty fluid.
Old Mar 1, 2007 | 05:19 PM
did you do it yourself? if so how much fluid did it take? and what kind?
thanks
Old Mar 1, 2007 | 07:49 PM
2k S4's Avatar
ORIGINAL: matoida6twin
thanks
Yes, I DIY, it's not hard, just messy.
http://www.audipages.com/Tech_Articl...nsmission.html
rmr1499
Jul 16, 2013 01:11 PM
the Anno
Sep 18, 2011 08:05 PM
vanbragt
Apr 18, 2010 10:45 AM
h8state
Mar 31, 2008 10:15 AM
jonno77
Jun 11, 2007 05:12 PM
