help with vibration on the highway?
Old Feb 1, 2008 | 11:08 AM
  #21
jaymac's Avatar
Default RE: help with vibration on the highway?
Thanks for the info on the tires! As much as they said the Yoko's were junk, comapred to what they were before they re-balanced them and removed the bent wheel, I have no complaints at all. They said the ride is not as perfect as they'd like it to be, but I'm more than satisfied.
Old Feb 1, 2008 | 12:33 PM
  #22
trapped's Avatar
I actually have the same problem. it only occurs at speed, but often times when im braking at high speeds its more violent. Also sometimes when im breaking at slow speeds i can feel the car lurching and slowing rather than just a smooth break. (hopfully you get what im saying) I was told that could be a bent caliper... how could i check the calipers/bent rim, propshaft without taking it to a shop?
Old Feb 1, 2008 | 12:53 PM
  #23
NH_USA's Avatar
Most likely a rim or disc.
The rim can be checked by jacking up the car, positioning a fixed object next to the flange on the wheel, and rotating the wheel. If the distance between the fixed object and the rim changes more than and eight of an inch I would suspect a bent rim. You nee dto do it on bothe the inside and outside - but the best way is to take it off the car and have someone check it on a balancing machine.
The disc is harder because you need to remove the wheel and use a dial indicator
Old Feb 6, 2008 | 07:27 AM
  #24
jaymac's Avatar
ORIGINAL: trapped
Yeah, I experienced the same thing, both at speed and also slowing. It's definitely better now with the improved balance and wheel swap, but still there slighlty. I know the back 2 are stilll slighlty bent and the tires are out of round, but I'm wondering if I could have a bad disc too?
Old Feb 6, 2008 | 10:28 AM
  #25
NH_USA's Avatar
Fix one thing at a time. Since the shop said the tires are OoR I would deal with the first.
redmond1501
Nov 27, 2012 08:28 AM
2005AudiA4
Dec 21, 2008 08:59 PM
3.0AmuletA4
Jul 1, 2008 01:18 PM
cooleststan
Jul 15, 2007 05:23 PM
Dudek12
Jun 8, 2005 05:40 PM
