Hesitation in Acceleration from a Stop
Did he use a throttle body off of a newer car, different model etc?
Mike
Does your engine rev but you get no acceleration? Mine revs and almost acts like the brakes are being applied. I don't think it's an adaptive thing. I'm something of an aggressive driver but have to be careful doing something like a right turn on red if traffic is moderate because I don't have any confidence in it.
I'll try the reset scheme but doubt it will do anything for me.
Thanks
Looks like we are not alone. My 2.7T hesitates a little from stop. Guess lots of Tiptronic owners have the same issue. Does not seem that big a deal to me, never had a problem gunning it and leaving others in my wake
http://www.petitiononline.com/ARTIP/petition.html
Throttle adaptation procedure for a C6:
1. Stick key in ignition and turn to the "ON" position.
2. Step on throttle all the way down and hold for 5 seconds.
3. Turn key all the way off while still holding throttle down.
4. Release throttle 2 seconds after turning key to "OFF".
5. You might be able to hear the reset taking place. You're good to go after a minute.
I'll try 30 seconds though and see if that works.
All of these are settable in the computer also. Had a tech do that once and it seemed to have no effect so I concluded it must be a part failure of some sort but a scan for error codes never shows any.
My newly acquired '07 A4 Avant 3.2 is experiencing the same hesitation off the line as described by a few members in this thread. When I depress the gas pedal there is a distinct lack of response for 1-2 seconds. I am not 'granny driving' nor am I looking to leave a patch of rubber on the road, just get rolling smoothly and decisively.
There are a some suggested fixes such as cleaning the throttle body and reseting the ECU using the key position and throttle. Did any of these approaches work effectively? Are there other suggestions?
Thanks!
Thanks!
