HID upgrade
Old Jul 3, 2006 | 01:55 PM
prbayha's Avatar
Default HID upgrade
I would like to upgrade the headlights in my 2001 A6 4.2. Does anybody have any suggestions for a quality kit? I would also like to know if it is possible to chip the car.
Thanks
Old Jul 3, 2006 | 02:17 PM
SouthboroAudiGuy's Avatar
Default RE: HID upgrade
I'll let others tackle the headlight question, but here's the scoop on chipping...
You can chip a 4.2. You will NOT, however, see anywhere near the gains in performance that you would when chipping a 2.7T. In the case of the latter, modifying the ECU achieved added horsepower by boosting the turbos. Given that the 4.2 is a naturally aspirated engine, the gains produced through this technique are not possible. I think you get a few extra horsepower and remove the speed limiter (normally, the gas kicks off at 130 MPH). Check out www.goapr.com for details.
Old Jul 3, 2006 | 06:31 PM
quattromond's Avatar
Im intrested in knowing about the HID kit also, but its for my 96 A6.
Old Jul 6, 2006 | 02:16 AM
prbayha's Avatar
Thanks for the info...It doesnt sound like it is worth it...I heard you can chip the tranny to change the shiftpoints...That alone would be a huge advantage...I will check out the site you mentioned.
Thanks
Old Aug 9, 2006 | 06:40 PM
dcdesign2000's Avatar
My 2000 A6 4.2 has HID, but the clear covers are all discolored/ yellowish.
Is that something I can just clean up with a special solution or can I change its casing?
Old Aug 10, 2006 | 12:02 AM
There is a technique to cleaning the lens, its sunbacked thats the term, its got a yellowish haze on it,
I belive if you talk to a body shop they can do it for a price or you can do it your self. depending on how bad it is depends on if its cleanable. I have use rubbing compound, what bodyshops would use to buff a cars paint to a shine, its the same process but you will need a highspeed buffer.
Old Aug 10, 2006 | 07:37 AM
Propagandalf's Avatar
As for the kit ....
http://sonolithics.com/files/a6_links.html
Go to the lighting section, it discusses HID swaps from other Audis. If you are looking at a plug-and-play kit, I cant help you there, and I'd like to know myself.
As for the yellowing headlights, you can use ultrafine sandpaper and follow with an orbital buffer and rubbing/polishing compound until clear. You can change the housing cover itself if you are more mechanically inclined, just look on ebay, the covers pop up every once in a while.
Audi=Happiness
Apr 30, 2008 01:57 PM
stromo
Apr 23, 2008 07:21 PM
auditt225
Jul 20, 2007 03:56 PM
BadLuckAudi
Oct 14, 2005 02:30 AM
Dudek12
Oct 13, 2005 12:44 AM
