hidden features ?
Old Dec 28, 2007 | 12:49 AM
Figgy1682's Avatar
Default hidden features ?
i did a search on this first and only found the eq feature, are there any other hidden features on a 01 a6. dont flame me for this please i was looking around the forum and found it on other models.
Old Dec 28, 2007 | 10:10 AM
Limen's Avatar
Default RE: hidden features ?
eq feature?
Old Dec 28, 2007 | 10:48 AM
Teutonic2.7T's Avatar
ORIGINAL: Limen
eq feature?
2nd that!
Old Dec 28, 2007 | 11:12 AM
MiniSpdRcr's Avatar
This....find your radio on here and it tells you how to do different things on it Oh its in the programming guide.
http://www.ibiblio.org/tkan/audi/radios/
Old Dec 28, 2007 | 12:00 PM
Hidden Equalizer
The following is the procedure on how to access and adjust the "hidden" equalizer feature in the Audi Symphony radio.
Turn off radio.
While pressing and holding the Preset 5 button, turn on radio.
You'll see a series of 8 digits displayed. From the factory, it's set to "55555555". You will not hear any sound when running in this mode.
The first four digits correspond to the four equalizer bands (low, low-mid, upper-mid, high) for the front speakers, and the last four digits are the same for the rear speakers. The level can be set from 1 (minimum) to 9 (maximum).
Turn the volume control **** to increase or decrease the level for the band (which is blinking). To advance to the next band, press the P.Scan button.
When you are done, turn off radio, then turn it back on to hear the results. On some versions of the Symphony, you must also cycle the ignition key to hear the results. [/ol]
Old Dec 28, 2007 | 12:59 PM
AZAudiA6Q's Avatar
So what does adjusting the bands do for your sound quality if your turn them up? I don't know much about audio equipment.
Old Dec 28, 2007 | 02:50 PM
Limen's Avatar
ORIGINAL: AZAudiA6Q
Me either, what would I do with this once I have it up? Anybody know that best settings?
Ambush
Mar 1, 2014 04:16 PM
fidelite
Jun 28, 2008 04:30 PM
esandes
Feb 22, 2008 11:01 AM
peteops
Nov 14, 2007 02:52 AM
skunkoncrunk
Feb 26, 2007 07:05 AM
