Hot rotor?
Old Apr 24, 2017 | 12:08 PM
rocketva's Avatar
Default Hot rotor?
Replaced the passenger side, rear, caliper, rotor and pads and now it is VERY hot after even a short drive. No warning lights. I am worried that maybe the EPB is not disengaging. Can these get out of sequence?
Appreciate any suggestions.
Thanks.
2005 Audi A6 4.2 Quattro Tip
Old Apr 24, 2017 | 11:45 PM
twopedalwarrior's Avatar
did you bleed the system? It sounds like your caliper is pushing the pad against the rotor
Old Apr 25, 2017 | 09:55 AM
rocketva's Avatar
Brakes were bled-pedal height and feel is normal.
Old Apr 25, 2017 | 07:55 PM
Well obviously the caliper is pushing against the pad if its getting hot. did you not place the spring clip properly? or is the ebrake cable not adjusted properly?
Lotus49b
Aug 17, 2009 01:13 PM
M3Armand
Oct 17, 2007 11:08 AM
blkapra4
Jul 25, 2006 09:52 PM
