2.7 Engine Removal
The easiest way to do this is to purchase the manual. I know it is $80 that could be spent elsewhere, but if you get the cd rom version, you can print out the relevant pages, get them dirty, check things off, etc. It will walk you through this process. It is not that hard, but there is a lot of ground to cover. Start with the right tools; knowledge!
Best of luck!
Best of luck!
Do yourself a favor. It'll take quite awhile but can be invaluable if you're not intimately familiar with the entire engine bay. Buy a few sheets of small adhesive tags. When you unplug the first connector, label both sides (engine side and harness side) as "1" and continue on with 2, 3, 4, etc. Later when you reinstall the engine, just match the numbers up and you won't have to worry about making incorrect connections. Do the same for any vacuum lines as well. It'll seem tedious but you'll be glad you did it later.
Search the B5 S4 forums, here and on AZ, there are lots of posts with details
Just checked my bookmarks and found this, not the one I used but it'll get you in the right direction
http://vimeo.com/5238276
Okay so the engine is completely disconnected. But it will only come an inch from the transmission and the engine wont come off any more. I watched that video just now and the only thing i didn't do was put it in reverse. I need this engine out now!!
Please call/text me if you have any idea whats wrong 720 560 7168
thank you guys for helping.
http://www.audizine.com/forum/showth...ngine+pull+diy
http://forums.audiworld.com/showthre...577529#2187139
I spoke with a good source, he suggested getting the engine up high to clear the downpipes, put the trans on a greater angle, and pull like heck
Thank you very much, the one on audizine i am probably going to read through, and watch that video a few more times to double check my work and start tuggin early morning. But thank you very much Ryan. Any more info would help greatly though, and would you suggest pulling eng/tran on the allroad or just pulling the engine tomorrow. Because the allroad wont have the clutch crap to worry about. The trq converter just just slide right out on it. Input? Thank you again.
EDIT: Ah..... I think I got this, I kept reading through, found the pics and the video ( kinda retro looking but hey it works)
Last edited by JohnnyBob; Apr 27, 2017 at 03:02 AM. Reason: Found My answer's, just didnt continue looking before state a question, not tryin to spam intentionally dudes 8)
