how to check wastegates
Old Jun 9, 2010 | 10:49 AM
SILVER A6 2.7T's Avatar
yea i can check but i have replaced the TBB,F-hoses,Y-pipes,and the little hoses that connect the dv's to the bi pipes with silicone. but its raining now and i dont have a garage to look at it in yet but as soon as i can i will and i will clean the MAF sensor.
Old Jun 11, 2010 | 10:44 AM
so i cleaned my MAF and my air filter still no better than it was. Auditech you said it could possible be a ignition problem, what exactly? bad coil?
Old Jun 11, 2010 | 06:24 PM
auditech79's Avatar
No, now were done shotgunning. When you get a vag com we need all the available data. Throttle body, O2 sensors, fuel trims, misfire data etc.
You DID clear the fault codes after cleaning the maf though right?
Old Jun 13, 2010 | 12:09 AM
i never had any fault codes. nothing has come up since this this problem started but after i cleaned it i did reset the ecu but like i said same problem. i guess its time for that vag-com now i hope i can find someone willing to let me use theres in my area cause they are expensive arent they.
Old Jun 13, 2010 | 01:51 PM
auditech79's Avatar
The software is free, the cable costs about $400 from ross tech, and its worth every penny.
Old Jun 14, 2010 | 01:18 AM
hey which one do i need for my car? 2000 a6 2.7t quattro
Old Nov 8, 2010 | 02:00 PM
ok well i cant a vag-com but i did read somewhere about disconnecting the n75 electroniclly which i did and now im getting 12psi through every gear. does this change anything or do i still need to get a vag-com?
joeynach
Aug 27, 2011 06:57 PM
parlayin
Feb 10, 2010 12:33 PM
MeanAudiA6
Feb 7, 2008 01:16 PM
TKneedsS4
Oct 23, 2007 10:31 AM
