How to fix P1545 issue?
Old Apr 8, 2012 | 02:41 PM
retrodriver's Avatar
Default How to fix P1545 issue?
Hello All, new to the forum...
So I bought a 99 A6 quattro Wagon...A neighbor told me he saw my brake
lights on all night...I go out the next morning and sure enough my battery
is dead...I take out battery, charge it and install a new brake light switch.
The good, the brake lights are no longer on. The bad, installed the freshly
recharged battery and the car cranks over but will not stay started unless
I keep my foot on the pedal and gas it over 2k rpms...Code on my obdII reads
P1545...Sheesh, all from a dead battery and brake light switch...Is there any
sort of easy fix for this issue?
Thank you so much for the help forum members...
Old Apr 8, 2012 | 02:49 PM
Wow, just finding that this issue is common and there are other threads on this..
so it looks as if I need a vagcom to take care of this issue...Any other help would be
appreciated...Can this issue be taken care of without vagcom?
Old Apr 18, 2012 | 02:21 PM
copper07's Avatar
Did you find the fix for this?
Old Apr 18, 2012 | 04:27 PM
budhani786's Avatar
I think* the reason this happened to the OP is because after he reconnected the battery he didnt perform a throttle body adaptation.
Old Apr 19, 2012 | 11:50 AM
Default update
Acutally, even after installing the brake switch, my brake lights are still on all the time but now only when the headlights are turned on...
I paid a mobile mechanic who has a (snap on obdII) to come down and re align the throttle body and such($80 charge).. So the car starts and runs again although still have the brake light issue..
Thanks all for the help and comments.
Old Jun 28, 2018 | 12:34 PM
Tim Leyba's Avatar
Default Need help fixing p1545 fault code
I have a. P1545 fault code i bought the vcds cord off of Amazon and down loaded the free software it helps alot i can see alot more of what going on with my car but it wont go inti advanced setting like fixing the throttle body i am in a really panicked situation here.PLEASE SOME EITHER WITH A FULLY FUNCTIONAL VCDS UNIT OR SOMEONEWN ? OR KNOWLEDGE ON THIS PLEAAE HELP
loft01sf
Jan 4, 2014 10:03 PM
ScGiants28
Jan 22, 2013 12:08 PM
konajuggler
Aug 24, 2009 08:05 AM
kaviner
Dec 3, 2008 01:01 AM
sptriple
Oct 28, 2007 11:38 PM
