Mysterious problem
Old Sep 13, 2009 | 03:50 AM
xewax's Avatar
Member
Default Mysterious problem
Hello,
I will try to explain my problem, before that i want to say that i have checked my car in three different auto services and no problem was found.
Well, when I turn left lets say 90 degrees I hear a strange sound coming from the back of the car. Its like "tuk tuk tuk.." And it also depends on a speed. What it could be?
Old Sep 13, 2009 | 05:54 AM
Kevin's Avatar
Since you have not provided us with any information regarding your car, such as year, engine, transmission, etc., or whether the noise is louder at higher or lower speeds, I am going to guess that when you make a left turn the watermelon you left in your tunk rolls across the floor making the noise you are hearing.
Old Sep 13, 2009 | 10:09 AM
Midniteoyl's Avatar
If its a Quattro it could be the rear diff or rear CV joint. Mine makes this noise at close to full lock in the front.
Old Sep 13, 2009 | 03:13 PM
xewax's Avatar
Member
Its not Quattro, 2001 1.9Tdi, sedan. Manual transmission.
Usually i hear it driving the first gear when I turn left.
Old Sep 14, 2009 | 12:00 PM
bob martin's Avatar
The tuk, tuk, tuk suggests a repeating interference, which leads us to the wheels. The "when turning left" implies a problem on the right side (the loaded side). When turning implies the wheel bearing. It could be as simple as a little play, but you would think that at least one of three mechanics would have found that. I would take the right rear apart and look for signs of something hitting something else and I would replace the bearing just to be sure.
Good luck,
Bob
Old Sep 14, 2009 | 01:09 PM
NH_USA's Avatar
I don't agree with Kevin cause a watermellon would go thud thud not tuk tuk
But the brake backing plate might be too close to the rotor and it is hitting when things are flexed a bit
Old Sep 14, 2009 | 04:49 PM
xewax's Avatar
Member
Good luck,
Bob
You must be right. Its the only one reason i think.
Old Sep 14, 2009 | 04:53 PM
xewax's Avatar
Member
Im going to change rear brake pads in a few days and rear break pads are very slim, can it be a reason? Saying slim i want to say its really slim its time to change them.
Old Sep 14, 2009 | 09:37 PM
Midniteoyl's Avatar
A good ripe melon will go tuk, tuk
Old Sep 15, 2009 | 12:37 PM
NH_USA's Avatar
I have little experience with rip mellons but am willing to learn- if you know someone that is willing to teach me I'm ready.
Brake pads might be rattling in the calipers but I was talking about the backing plate being too close to the rotors.
starving030
Feb 27, 2014 08:12 AM
Tamms
May 12, 2012 02:27 PM
Twistedfreedom
Oct 27, 2010 02:06 AM
mnsirx
Jul 10, 2007 09:58 AM
dunnidun
Dec 15, 2006 12:58 PM
