N00b here, question about brake lights
So I bought a 2000 A6 2.8 Quattro today (yay me) and overall the car is in good shape. Needs a few interior plastic bits here and there, but I have already found them and my total cost is like $220 so that rocks.
My question is about brake lights. They don't work. LOL. I have checked the bulbs. They are fine. I also checked the fuse, and it is fine as well.
Not really sure on this what to check next (wiring I presume), but not sure where to start. If someone could point me in the right direction, that would be Fantastic
Any abs brake signs on the dash? The orange ESP light?
Brake switch was my next step
and I have a flashing brake light on dash, but it looked like the brake fluid might be a bit low as well, so I need to go get some of that
I suspect the ABS module is out as well however...
if the ABS module is out, it should give you the dreaded "three beeps" along with the flashing brake light.
I'm with the other guys on the brake switch. cheap and easy to replace. if that doesn't do it, then move on to the more complicated/expensive
