Need help installing air filter on A6 4.2
Old Feb 23, 2008 | 07:15 PM
4.2a6's Avatar
Default Need help installing air filter on A6 4.2
Need help with install of new air filter on 2001 4.2.
Thx
Old Feb 23, 2008 | 09:53 PM
joetm's Avatar
Default RE: Need help installing air filter on A6 4.2
me too!
Old Feb 24, 2008 | 10:08 AM
dmrdennie's Avatar
There's a cover over the air filter housing. It's on the passenger side of the motor. Remove this and the duct that goes to the front. Underneath the cover, you'll see the filter housing that has the retaining clips that most are used to seeing. Unsnap the clips, remove the fliter, install new and put it all back together. It's kind of tricky to mate the housing surfaces back together but it's not that hard. Hope this helps.
Old Feb 24, 2008 | 01:47 PM
mustang196718's Avatar
be careful when you unsnap the clips too. they have a tendancy to fall out from the bottom of the airbox and it makes it a little tricky when putting it back together. the duct that goes to the fron that he's referring to is held in by 2 screws that you should be able to see when you open the hood. you might also need to remove part of the intake piping so that you can get the top all the way off.
Old Feb 24, 2008 | 03:38 PM
NH_USA's Avatar
That's a simple one --At least you don't have to remove the motor and front bodywork to get at it!
Old Feb 25, 2008 | 12:18 PM
Limen's Avatar
ORIGINAL: NH_USA
That seems a little hardcore.
Old Feb 25, 2008 | 03:09 PM
A6in08's Avatar
I have a 00 4.2 and I have actually just replaced my air filter this past weekend with a K&N. I have found out that if you take the screw out that holds the bottom of the airbox onto the frame you can move the unit around to give you a little more play when trying to access the clip on the lower left corner. This was the toughest part for me. I have some video of it if you need more assistance. Please email me.
Old Feb 29, 2008 | 10:34 PM
joetm's Avatar
the clip in teh back is a PITA took me 30 mins to get one freakin clip ... i thought this thread was for the cabin air filter ... does anyone know where that is i gotta throw this one i just ordered in as audi recommends i change it at 65k
Old Mar 1, 2008 | 09:33 AM
beng's Avatar
WHO HELPS YOU PEOPLE WHEN YOU HAVE A FLAT TIRE? beng
Prizmatik
Sep 20, 2008 02:04 PM
Leifer
Oct 2, 2007 08:10 PM
mauricewong
Aug 1, 2007 04:53 PM
Pablo_Ottawa
Apr 19, 2007 12:34 PM
Decivs
Sep 11, 2006 05:13 PM
