Need HELP! Weird electrical problem, brake lights always ON!
Old Jun 13, 2010 | 04:46 PM
auditech79's Avatar
Its either a short or a bad module at this point, but the module needs to the correct one.
What are the fault codes in the brake electronics? If you can't communicate with the ABS/brakes it probably is the module.
Old Jun 13, 2010 | 04:52 PM
jpcallmotor's Avatar
Bosch 5.3 module correct? A faulty module can cause these types of problems? I guess it won't hurt to try it I've got one. I do not have VAG-COM and have not communicated with the brakes at all. All I have is an OBDII code reader... Thanks for the reply!
Old Jun 15, 2010 | 11:13 PM
UPDATE: I put in another ABS module from a donor car and, it does not seem to make any difference.
-brakes lights stay on with headlights but work fine with headlights off.
-the front passenger marker lights up when ever hit the brakes.
-Dash say "Brake light" but all bulbs are new and working. Also it makes a "beep' every 30secs pretty much. (extremely annoying)
-ABS light on as well as the BRAKE light blinking
Again Thanks. Any input would be greatly appreciated. Thanks
Old Jun 16, 2010 | 06:49 PM
auditech79's Avatar
No one can give you anymore input until you pull the fault codes. Thats like asking my engine stopped working, whats wrong with it?
Old Jun 16, 2010 | 09:23 PM
NH_USA's Avatar
I know the answer to that one!!!!
It's broke!
Old Jul 14, 2010 | 10:00 AM
upallnight's Avatar
Are you sure it's the Brake light and not the Fog light.
fromerich
Nov 27, 2009 05:48 PM
auditt225
Dec 19, 2008 10:35 AM
lumend13
Oct 27, 2008 01:42 AM
CheeseHead
May 14, 2007 10:47 PM
alexaudiA4
Apr 26, 2006 01:42 PM
