oil change 2001 2.7 T
Old Nov 27, 2005 | 09:26 PM
pkony's Avatar
Default oil change 2001 2.7 T
I just got this 2001 A6 2.7 T and while changing my oil I could not get the oil filter off. The oil filter is right next to the oil pan, correct? I just want to make sure this is the oil filter location and I'm not messing with some other filter. Thanks.
Old Nov 28, 2005 | 03:35 AM
mastvadz71's Avatar
Member
Default RE: oil change 2001 2.7 T
you need a big plaers to untight the filter ,ruber drys from hi temp.get anoder set of big pliers and hold the oil cooler othe rway it will move wich may cose coolent leak later.don't worry,you can do it
Old Nov 28, 2005 | 07:46 PM
techbod's Avatar
oil filter removal tools
http://images.google.co.uk/images?q=...al+tools&hl=en
[IMG]local://upfiles/12092/5FD86EA6082041E081875FD177243A93.jpg[/IMG]
Old Nov 29, 2005 | 05:49 AM
dankhound's Avatar
Using oil on the rubber seal will not only help it seal better, but it will also make it easier the next time you change the oil.
Old Nov 29, 2005 | 10:01 AM
misko's Avatar
actually putting oil on the seal(gasket) prevents it from twisting out of shape and leaking after installation.
Old Nov 30, 2005 | 06:19 PM
dankhound's Avatar
Thats what i thought i said, but i guess my english really is as bad as i thought it was.
Old Dec 1, 2005 | 03:59 PM
pkony's Avatar
Thanks for all the help.
waffles7622
Mar 24, 2011 03:29 AM
pdxorcubsfan
Mar 25, 2009 06:04 PM
Gibson2687
Aug 11, 2006 09:47 PM
princessleanne
Jun 16, 2006 12:15 AM
choraltech
Nov 29, 2005 05:42 AM
