Over heating problem!
I drive a 95 A6 2.8l. I have serious over heating problems. NO CLUE WHAT IT IS! No white smoke from my exhaust. My thermostat is punched out, thought that was the problem so did a redneck repair. didnt help. what do you think?
Once the coolant temperature is raised to the operating temperature, turn the car off and run your hand over the radiator. If you the radiator is cold all over, then your system is plugged somewhere. If you feel a huge difference in temperature on the radiator surface, then your radiator is bad.
You mentioned that the over heating is serious. How serious? Did you check to see if your fan clutch is working properly?
Coolant flowing via the bleeder screw will not confirm a bad water pump. A bad pump can still circulate coolant, but not enough.
