P0101 error, black smoke, holds back
Old Jan 2, 2013 | 06:07 AM
texaspete's Avatar
Unhappy P0101 error, black smoke, holds back
Hi.
I have a 2007 A6 C6 2.0tdi.
Today it has started holding back and throwing black smoke out the exhaust when i accelerate.
If you rev it gently it's fine but put your fut down and it misfires and smokes.
The computer shows P0101 which is MAF sensor but I am not convinced.
When cruising its fine and pulls well when the revs are high enough.
I have sourced a MAF but would welcome any suggestions???
Mant thanks.
Old Apr 18, 2017 | 11:24 AM
Anashuss's Avatar
Originally Posted by texaspete
Hi.
Mant thanks.
this is the exact same problem i seem to be having and would appreciate any updates
Old Apr 18, 2017 | 12:17 PM
twopedalwarrior's Avatar
sounds like your turbo is shot
Old Apr 18, 2017 | 01:16 PM
Anashuss's Avatar
Default turbo
thankyou for the reply garage has just advised the same i pray it all goes well will have it sorted soon and post back
Old Apr 19, 2017 | 10:17 AM
texaspete's Avatar
Hi.
I sorted it out.
It was the EGR valve. The valve itself has snapped inside so was letting exhaust fumes through all the time, suffocating the engine until the revs got up.
The picture shows the problem. The black disc at the top of the photo is the vavle and should fit in the unit. Cost my about £140 from ebay and 40min to fit. Not a big job.
Hope this helps.
Old Apr 19, 2017 | 07:00 PM
nice find
Old May 10, 2017 | 02:39 AM
Anashuss's Avatar
Default Re:Update vehicle repaired!!
Hi guys many many thanks for all of your help after spending so much time and money it did turn out to be the egr a small pin was snapped i know somebody did suggest this to me earlier unfortunately i cannot find the post to let them know. I will aim to attach a picture of the specific part which only cost £60 second hand and as soon as it was replaced the car works wonders!!! Better than before!!
Old May 10, 2017 | 02:43 AM
Anashuss's Avatar
Default Thanks
[QUOTE=texaspete;1417979]Hi.
Hi i would just like to say many thanks for your help i had the exact same issue in the end and really appreciate your prompt reply
Hendref
Apr 19, 2017 09:24 PM
DCAV8R
Feb 18, 2012 02:18 PM
a6in
Mar 19, 2008 06:45 PM
binzer33
Feb 9, 2007 02:46 PM
AKA
Aug 22, 2005 03:54 AM
