P0130 O2 Sensor Bank 1 Sensor 1
Old Jan 14, 2011 | 11:06 PM
BSDULAY's Avatar
Default P0130 O2 Sensor Bank 1 Sensor 1
Hi
I had some checked my 2001 audi a6 avant quattro , and I got this engine trouble code P0130 O2 Sensor Bank 1 Sensor 1. Im assuming this is the oxygen sensor in the front passenger side. But, can anyone direct me to the exact location for this? Also, Can I change it in my garage? Or does it need special tool or configuration?
Also, once this has been replaced, should i have the code reset? Or it will automatically do it?
Thanks
Old Jan 15, 2011 | 08:04 AM
Jackmup's Avatar
read this thread
https://www.audiforums.com/forum/sho...d.php?t=163010
there is a special wrench to remove these. It has an opened end so you can slide it over the wire. Try your local auto parts store or sears.
reset the mil with any scanner
Old Jan 15, 2011 | 02:40 PM
BSDULAY's Avatar
Oh wow. That looks complicated. I thought I can just crawl under and change it.
Old Jan 15, 2011 | 05:29 PM
hxgaser's Avatar
Old Jan 15, 2011 | 07:27 PM
Jackmup's Avatar
You don't have to pull the head!
I just took that picture to show where they are. LOL
That wouldn't even be funny if you did that. Ok maybe a little.
Old Jan 15, 2011 | 11:22 PM
BSDULAY's Avatar
Pfew!!! Thanks HXGASER!!!
I was really stressing out on Jackmup's pictures! Hahaha! But thank you guys for the input! Awesome help!
Old Feb 14, 2011 | 07:06 PM
mor3lia's Avatar
delphi ES20164 is that the upstream sensor or downstream?
Old Dec 23, 2011 | 01:46 PM
jthompso4's Avatar
what is the best way to access the B1S1 from the engine compartment. You said you didn't have to remove the header, but i only see the post cat oxygen sensor from top of car. I have the 03 a6 3.0 and i need to replace the B1S1 oxygen sensor. i was hoping to replace myself, and save a little $.
Old Nov 4, 2016 | 11:03 AM
Frebay's Avatar
Hello...2003 A6 3.0 quatro. 160,000 KM. Code B1S1, bought Bosch Sensor, thinking of replacing myself. Can access from top passenger side, but can't seem to locate the plug location. does it plug in on firewall passenger side. (it is the precat/upstream O2). Finally, will it reset the light after driving a bit.? help appreciated.
Butchco2002
Sep 12, 2013 10:15 AM
alex5652
Oct 6, 2010 02:26 PM
brent07
Jan 19, 2007 03:57 PM
