P0730 Incorrect gear ratio- Help
I just purchased a 2001 A6 4.2L with 83K miles, the transmission was in limp mode and I scanned it and got P0730 (incorrect gear ratio). When I put the car in reverse, it works flawlessly but not forward- it goes into limp mode. I erased the code and it came right back. I read a lot about it, the more I read, I more I got confused. Did anyone have the same problem and had it fixed? It is something not too costly to repair which I may do myself with the help of a friend. I need all the help I can get. Thank you
Thanks for sharing your experience. Do you mean that the fluid will fix it then the tranny needs replacing? When I put it in drive or any forward gear, I get nothing until I rev the engine then it goes into limp mode then it will drive but assuming on 4th gear, but the reverse is fine. If the fluid is low wouldn't the reverse not work either?
Try searching on your subject as others have had this issue. Most of these seemed to have needed a new transmission but, IIRC, there is a DIY (if you a very mechanically inclined!!!) on how to rebuild this transmission.
Hope you knew this before you bought it.
Bob
Bob
This - at least - is one of the threads including some info on rebuilding the tranny. You can do a search on "transmission" for the A6 forum and come up with more threads/information that discussed over the limp mode issue - as Bob already suggested.
well, I changed the filter and fluid today, the fluid was dark but not burnt, the filter on the other hand was cracked on the top. There was no metal shavings on the magnet other than the usual tar. I put about 6.5 liters of ATF and i followed the procedure step by step. I tried it and it is still the same with limp mode and code P0730... I am not sure what to do. Could it be the solenoids or the transmission module? I am not sure what to do. Any suggestions? Thanks for all your help.
Pull the connector on both the TCM (under the carpet on passenger's side) and the connector to the trans itself and look for any bent/corroded pins. If you got the fluid in correctly another problem it could be is with the TR (transmission range) switch. It tells the TCM which gear you are in, if it get the incorrect signal it will put in in limp mode (3rd gear permanent) and make it feel like its slower than hell.
BTW, please tell me you didn't put in a standard ATF in this trans?
