P0730 Incorrect gear ratio- Help
Its in front of the passenger's seat inside a black box. You have to open the box to access the TCM. The vag com will generally sense if there is a problem with the TR via fault codes, but sometimes the linkage or TR switch will cause a gear ratio fault code.
What procedure did you follow to fill the trans? Its really easy to mess it up.
How do I follow the proper test procedures to eliminate the solenoids, TCM, sensors issue etc. Is there a procedure to test this or a manual? Thanks for your help and time again.
Yes, the TCM is almost directly in front of the seat, you have to remove the door sill to get at it, its sitting down in a sump.
As for the procedure, 100 degrees is a too hot. If you haven't gotten all the fluid in there by 33C (91F) about 6.5 liters it won't shift correctly and you can get this fault code. When the fluid gets to 100 degrees it will expand to the point where it will spill out faster than you can get it all in there. I would drain it back out, put about 4 liters in there before starting the motor. Watch the trans temp on the vag com, continue adding while shifting through the gears (you will need another person if you don't have the gravity feed tool) then when you are getting close to 30*C make sure you have already put in about 6 liters, if not, you won't make it. Its a pain in the *** procedure and it has to be done perfectly for it to work.
OK, I just bought a 4.2 with this same error code. A mechanic told the PO it was a bad sensor and you guys are sayign its fluid and a computer right? But has anyone here found it to be anything more serious? I searched and only found 2 thread both blaming fluid levels. I will be taking this to one of 2 mechanics and I just want to give them a good explanation of what they should look for before they just assume I need a trans rebuilt.
It should be only 3 seconds each...per Bentley manual
^^^good call, i didn't see that. I thought he said 2 seconds. Yeah if you are waiting 2 minutes in each gear you aren't doing yourself any favors, you will need to re-do this. You say you DON'T have a VAG COM? How the hell did you monitor the trans temp without the vag com?
No way you did it right with a temp probe, do it over again. Especially if you are hearing noises going into gear, if doing it the second time doesn't work, give it to a pro.
There is a way to diagnose a TC using the vag com monitoring the stall speed and TCC lock up, but if you don't know the specs you won't know what you're looking at.
