Sponsored by:
Sponsored by:
Please Help: Air Conditioning Problem
Old 07-16-2010, 05:27 PM
kingcu's Avatar
Default Please Help: Air Conditioning Problem
Another problem with my 2000 2.7T while it hits 90K, the air conditioner doesn't seem to work well. There are 4 air registers in the front, 2 on the driver side that blows out warm air, while the other 2 on the passenger side blows out cool air (but not as cool as before). The fan still blows pretty strong. The end result is that the cabin doesn't get cooled down in this hot summer weather. Any idea what this could be?
BTW, I am about to get a mechanic friend coming over helping me replacing the timing belt, water pump, etc. Any thing else I can do while I am at the TB to help out the A/C issue?
Old 07-18-2010, 07:20 PM
kingcu's Avatar
Any guess?
Old 07-18-2010, 07:33 PM
Jeffla's Avatar
I have a couple thoughts (ie guesses)
1. a door/damper is stuck and not directing the cold air to the drivers side.
2. the climate control is purposely sending warmer are to the drivers side due to some internal CC fault.
3. you have your driver side temp set to HI while the passenger side is set to LO. JK
A vag-com will help if you have any stored CC faults. You can also manually move the door/dampeners (although I don't know how). Stored CC faults will NOT set your check engine light. For the most part you won't know they're there.
I remember reading a long time ago about a way to manually diagnose the CC somehow without the use of a vag-com. But of course, that's all I remember about it.
edit: here is how you get there, but don't ask me what to do from there:
"The way to get there is quite simple. Press the recirculate button, keep it in, and simultaneously press the "up arrow" vent control. This will cause both the temperature displays to change to 0 and 00." JoeCaymanBWI
http://forums.audiworld.com/showthread.php?t=1727602
Old 07-18-2010, 08:44 PM
damnwhitedevil's Avatar
Mine blows cold...but makes a loud whinning noise under the hood when you turn it on. its not a belt so i have no idea
Old 07-18-2010, 10:09 PM
kingcu's Avatar
Jeffla - thanks a lot for the advice. I don't have a vag-com, so I tried the manual way and I DID get some diagnostic codes. According the article below,
http://www.audiworld.com/tech/int5.shtml
code 1 displays any malfunction info, so when the display is like "C - 01", I got the code "1 - 25", which didn't match any DTC code in the above link. Does anyone know what a "1 - 25" mean? Thanks.
jasonsat
06-18-2013 11:17 PM
Msgtjw
10-25-2009 12:47 AM
johna4
08-24-2007 12:20 PM
Heineken1688
06-29-2007 04:39 PM
Jonny D
06-08-2005 06:54 PM
Quick Reply: Please Help: Air Conditioning Problem
