Power window problem
Old Aug 23, 2009 | 08:57 PM
mikeeboy82's Avatar
Default Power window problem
'99 A6 - front passenger window would not roll up motor clicked but would not go up or down, I ended up pulling the window up, then still would not work up or down. Motor clicks and I can see cable moving slightly (maybe an inch) but it does not move the window at all. It does not seem like it is just a lubrication problem, I can move the window easily seems like something is physically keeping the window from moving but I cannot figure out what. Hoping someone else has had similar problem and can help me out. Thanks for any help.
Old Aug 23, 2009 | 11:30 PM
Jackmup's Avatar
I had it happen, it's the window regulator. I think they call it right not passenger. Idiots!
You will need some aluminum pop rivets and a rivet gun to complete the job.
While it's apart lube up the tracks with silicone spray. then do all of the other widow traks the best you can. The silicone makes a clear difference in how thw windows roll up.
links;
http://www.primepartssuperstore.com/...layCatalogid=0
http://www.partsgeek.com/catalog/199...regulator.html
Old Aug 24, 2009 | 07:55 AM
m000035's Avatar
Originally Posted by Jackmup
... I think they call it right not passenger. Idiots! ...
With a company that sells cars to both left hand drive and right hand drive countries, it makes sense to name parts "right" and "left." A "right" part is a "right" part in all countries, by a "passenger" part changes sides!
Good tip on the silicone.
Old Aug 26, 2009 | 04:53 PM
mikeeboy82's Avatar
Thanks for the help, I'll check that out.
Old Aug 27, 2009 | 09:22 AM
Jackmup's Avatar
Now that you say it that way it does make some sense, However if I owned a billion dollar auto manufacturing corporation I would name may parts as Driver/euro Passenger/amer. and eliminate the confusion. That would make sense. American cars are drivers /passengers what do they do with them in Europe (I guess they're screwed).
Thanks for explaining that.
little_town_audi_owner
Jul 12, 2009 03:27 PM
cleaudia4
Apr 2, 2009 08:31 PM
jrward
Feb 14, 2007 02:19 AM
Agro
Jun 12, 2006 03:07 PM
apoch
May 16, 2005 11:26 PM
