PRNDS only on reverse, need advice!
Old Oct 7, 2014 | 12:19 PM
Relyts's Avatar
Default PRNDS only on reverse, need advice!
Car: 2003 Audi A6 3.0 Quattro
Pulling code: P0706
Hello, I've started having a problem with the PRND flashing and the car going into limp mode ONLY when I go into reverse.
Now, the car does reverse when this happens, but when I go into drive the acceleration is sluggish until I restart the car and put it right back into drive. So basically the car runs fine unless I initially go into reverse. To add to that, SOMETIMES if I hold the shifter in a specific position, the reverse works without causing the car to flash PRNDS.
I was wondering if anyone else has come across this particular issue? I understand it could need a range sensor replacement, but could it possibly just be a matter of readjusting or cleaning a few things?
Old Oct 7, 2014 | 10:19 PM
UncleScar's Avatar
There are a few threads on cleaning some contacts in the shifter. Search the forum search for the write up. Key words shifter, cleaning, shifter contacts. ect. But that code meant a new tranny on mine
Old Oct 8, 2014 | 02:44 PM
muppet's Avatar
Hi,
does it go into reverse with a real lump when it does this, as mine does exactly the same thing and when I plugged in my Snap On scanner it came up with lock solenoid not disengaging.
Pulling code: P0706
demonc18
B7 Models
Jul 28, 2015 02:58 AM
Kasim
Sep 5, 2013 11:06 AM
Kasim
Aug 26, 2013 08:14 AM
rlquattro2003
Mar 21, 2013 10:44 PM
mshprojects
Sep 1, 2008 07:01 PM
