In the process of buying a 2001 A6 3.0 Quattro
Old Apr 20, 2009 | 01:04 PM
sunnyv's Avatar
Default In the process of buying a 2001 A6 3.0 Quattro
Hi all,
I just in the process of buying this Quattro, it has 67K on the clock and has a trip tonic box. The car loks like in good shape and ive done a HPI check on it and has come out all good.
is there anything I need to look out for befoer I buy it ?
Thanks in advance
Sunny
Old Apr 20, 2009 | 06:00 PM
99A6Q's Avatar
first of all, figure out what year it is because the 3.0 wasnt avaliable until 2002. Secondly, just the normal things that are covered on this forum all the time. Figure that the timing belt/water pump will need to be changed in a year or less and thats a $1000 service assuming it hasnt been done yet. Other than that, just look at it like a normal used car, make sure it hasnt been wrecked and no apparent leaks.
Old Apr 20, 2009 | 06:12 PM
chefro's Avatar
Originally Posted by sunnyv
Hi all,
I just in the process of buying this Quattro, it has 67K on the clock and has a trip tonic box. is there anything I need to look out for befoer I buy it ?
If the seller includes the Gin with it, I would stay away from it.
Old Apr 20, 2009 | 06:22 PM
Jeffla's Avatar
You would be better off avoiding the 3.0l engine. And the reference to a 1k timing belt job does not apply to the 3.0l engine. The timing belt job on the 3.0l is much much more expensive.
https://www.audiforums.com/forum/sho...%27t+spit+fire
My favorite quote of all time "I wouldn't spit on a 3.0L if it were on fire, i hate them that much." Auditech79
Old Apr 20, 2009 | 06:33 PM
Jackmup's Avatar
Drive it some more and make sure the transmission shifts well D is regular drive S is sport and the gate lets you shift like a standard. The Transmission would be the only huge pitfall. Other than that mine has 113K and I just put $1K in parts into it Runs smooth as silk. Be sure to change the Timing belt! Also the orange coil packs are Known to fail so I would order a new set or at least one and put it on the shelf so your ready.
Old Apr 20, 2009 | 09:04 PM
a6xlr8s's Avatar
Put it on a rack and pull the belly pan. check for leaks!!! Also look for overspray and collision repair!
Old Apr 21, 2009 | 02:50 AM
sunnyv's Avatar
U hate the 3lt that much !!! cant be good
Old Apr 21, 2009 | 10:14 AM
crazyguy's Avatar
this makes me so excited about changing out my tb.
robsa6 00
Sep 25, 2014 04:57 PM
E90-GTE
May 5, 2012 11:16 AM
toomuchal
Jan 9, 2011 01:20 AM
ktcb721
Dec 14, 2007 11:00 AM
ConvertedJDMjunkie
Apr 12, 2005 09:01 PM
