Question, TOTAL Audi n00b!
Old Nov 3, 2008 | 12:53 AM
brodsA6's Avatar
Default Question, TOTAL Audi n00b!
This is my first Audi after 2 BMW's so I'm completely new to them.
I got a VERY good deal on my 2001 A6 2.7T with 82K.... But the check engine light is on. I got an O2 sensor fixed, then the other one went out and they said that it pulled another code.
It was some actuator, he said that word and associated it with timing. Anyone have some insight before I get the actual codes?
THANKS!
Old Nov 3, 2008 | 09:33 AM
hxgaser's Avatar
Get the code.
Old Nov 3, 2008 | 01:01 PM
NH_USA's Avatar
Ditto - Get the code
Old Nov 3, 2008 | 02:44 PM
ppgoal's Avatar
Autozone will pull your codes for free. But expect them to try and sell you parts.
Old Nov 5, 2008 | 10:58 PM
brodsA6's Avatar
Ok, I found the codes that I found in the very beginning. I will be running them again this week sometime with a friend VERY familiar to Audis.
P1529 and P1131. The O2 sensor one was fixed, then apparently the other Bank 2 sensor went out....
Old Nov 6, 2008 | 12:14 PM
hxgaser's Avatar
P1529 is the cam shaft control circuit short. P1131 is bank 2 O2 sensor.
As for the P1529, did someone recently do a timing belt replacement on your car?
Old Nov 7, 2008 | 10:29 PM
brodsA6's Avatar
I'm not sure, I just got it. Is there a way to tell? If they did or didn't, how does it affect that code?
THANKS YOU SOOOOO MUCH!!
Old Nov 9, 2008 | 12:25 AM
hxgaser's Avatar
Camshaft control circuit codes are typically (but not always) related to bad timing belt job. These motors are pretty finiky and will throw a code if the cam gears are off by a tooth.
BTW it is somewhat hard to tell if the timing belt was replaced recently. You maybe able to tell by poping open the belt cover, but it will be hard to tell.
Old Nov 9, 2008 | 01:53 AM
brodsA6's Avatar
What are the ways to fix it? Is it an expensive fix, or just a new belt job?
DoctorMemory
Jan 12, 2011 09:18 AM
drumdork03
Jun 18, 2008 09:26 PM
Four Ring Circus
Mar 17, 2008 08:31 PM
guitar_man
Jul 28, 2006 07:33 PM
